318 Vistas, 1 Respuesta
Automatic dimensioning
I have set of random points in the workspace as shown in the figure. I want to automatically dimension those points (Linear dimension only) in the best possible way by using any programming language as shown in the right image (for example). Is there any better algorithm for doing it? Gzolehana
Etiquetas (1)
Kent1Cooper
en respuesta a: Anonymous
You may be able to use QDIM, which will give you more dimensions than you want, but it could well be quicker to use it and delete some, and adjust the definition points and/or dimension line locations for some of those that you keep, than to do them all individually.
Kent Cooper, AIA
