philip.barcy
866 Vistas, 2 Respuestas
SWEEP Command issue.
Command:
SWEEP
Current wire frame density: ISOLINES=4, Closed profiles creation mode = Solid
Select objects to sweep or [MOde]: 1 found
Select sweep path or [Alignment/Base point/Scale/Twist]:
Modeling Operation Error:
Error Code Number is 115063
Unable to sweep 1 selected objects.
I never had this problem. I am unable to resolve this issue as I have saved the drawing and close the AutoCAD 2022. Open it again and hope it works but it didn't! So I exploded the ring into 2 circles. I clicked both circles into Region and Subject both circles to become the thickness of circle so I can create the ring into the pipeline in radius by using Sweep command. But the error appeared as above (highlighted red). Please advise! Thanks!
Valentin-WSP
en respuesta a: philip.barcy
@philip.barcy ,
Try to SWEEP from the other end of line.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
philip.barcy
en respuesta a: Valentin-WSP
Found the cause of the problem is that the straight line is opposite of the radius line see the pic!
