07-28-2021
11:56 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-28-2021
11:56 AM
I think you are missing the point of the OP's ( @Anonymous ) message. I don't think it has anything to do with ortho projections.
The polyline will not extrude at that X,Y coordinate.
I copied it to the left by 10 units and the extrusion works as expected.
I tested moving/extruding until it failed.
The polyline must be moved at least 6 units to the left from its original position before it will extrude.
Why? The shape has a bounding plane of 127436.0, -6.811, 0 by 127612.0, 218.511, 0.
Certainly that should be an acceptable working coordinate range.
I drew a rectangle farther to the right and it extruded.
Why this shape at that XY position cannot extrude is curious.
Perhaps someone can offer an explanation.
Jerry
CAD Administrator
Using Inventor 2022
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
CAD Administrator
Using Inventor 2022
