ChicagoLooper
en respuesta a: Anonymous
You have a drawing with an orthographic projection. You can tell it's an ortho projection because when the view cube is in TOP view, you can see your object's top, front and side view.
You should not draw with an ortho projection. Instead, change your POV (point-of-view) to top, draw you object's 'top' view, then extrude along the z-axis for the object's height, When you change your POV to front or side, you can extrude along the x- and y-axes for width and depth. To view the extruded object from different angles, you can 'rotate' the view cube.
To rotate your view you can click directly on the view cube--click different surfaces (or corners) of the view cube to change your view. You can also use the dropdown menu in the ribbon to change the view.
Chicagolooper
