en respuesta a: leeminardi
Hi @leeminardi
Thanks for your suggestion. Yes, you are the right the order of rotations is important.  But I think, rotation (single value) defined in the block property is around Z-Axis, Kappa. From the 4x4 transformation matrix or 3x3 rotation matrix, kappa can be computed given the rotations order.  The rotation(single value) in the block property (in my case) does not correspond to any of the rotation angles.
Thanks again.
