Kent1Cooper
en respuesta a: john.uhden
@john.uhden wrote:
.... The textual objects come out
looking just fine. But the properties and entity data show only a "?"
.... The delta character does show up when exploding a C3D
segment label of an arc (simplex font). OMG, and it shows up in the text
editor.
.... Δ But when I look atthe mtext properties again it has turned into a "?"
Using a Style with Arial font, I get [Acad2019] on-screen:
Propeties:
Entity Data:
When I change that Style to use SIMPLEX.shx, all is the same except for the on-screen look of the other text characters.  When I change it to use TXT.shx, and put a Delta symbol into Mtext from the Symbols pull-down, the Delta character still appears on-screen, but in Properties and Entity Data it is replaced by:
{\\fISOCPEUR|b0|i0|c0|p34;Δ}
If I then EXPLODE that Mtext, it breaks the rest of it into separate Text objects around the Deltas, and creates a whole new Style called "MtXpl_ISOCPEUR" to accommodate the Delta characters as separate Text objects.
Kent Cooper, AIA
