07-27-2021
10:00 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-27-2021
10:00 AM
I use TTF fonts exclusively since they are searchable in PDFs that I send to clients. I dumped shx fonts because they weren't supported by PDF except through workarounds that make them lots more complicated.
The delta does work fine in the simplex.shx font. The delta is readable also in the properties palette.
Alt codes seem to go much higher than 255 but ALT 961 doesn't do anything. Alt 172 and Alt 940 create the same character so it could be overflowing.
(rem 940 256) -> 172
Could be a limitation of AutoCAD because ALT tables online go higher.
Architect, Registered NC, VA, SC, & GA.
