dbroad
en respuesta a: john.uhden
Using the arial font, I can type-in \U+0394 and get a delta in both single line text and mtext both when entering it the first time and when editing the text.  In the mtext editor, I can also use the symbols drop down to plop it in.  I can also use charmap.
One problem with the alt codes is that, unless you're a pretty fast typist, it switches focus to the ribbon for alt picking. Another problem is that the ALT 916 that references say represents capital delta doesn't work (at least with Arial).
Architect, Registered NC, VA, SC, & GA.
