- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Hi there,
I have created a simple block(square). Inserted it to empty drawing at (10,10,0). Selected the block checked the rotation in the properties, it is zero as expected. Rotated in 3D via HOME->Rotate, selected based point as (10,10,0) then Y axis rotation (Green orbit) entered value of 10 degrees for rotation. It rotated the the block correctly but when I check the rotation value in the properties of the block it is 90 degrees!. If I do the same thing but for X Axis the rotation in the property does not changes (stay zero). As I understand, the rotation in the block properties should be around Z-Axis.
Does anyone know what the rotation in the block property exactly represents? Thanks,
¡Resuelto! Ir a solución.
