07-21-2021
04:30 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
07-21-2021
04:30 AM
You can put PolyLines on a Diet with PLDIET.lsp with its PLD command, available >here<. It reduced the larger Polyline from 1210 vertices to 370 by using 0.2 units as the maximum length to straighten, and accepting defaults for the other options. You will need to experiment with the trade-off between reduced number of vertices and fidelity to the original shape.
[P.S. It can't be used directly on the .DXF file, but only in AutoCAD in the .DWG file as you posted.]
Kent Cooper, AIA
