- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Converting PDF to DWG not working
When importing PDF into AutoCAD, the pdf converts as a image. My concern is the PDF has too low resolution or PDF may have embedded securities to not be able to convert.
Is there another solution to convert the PDF to a .dwg format?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hello SaladHead22,
Other solutions are just 3rd party software which you can Google, but using AutoCAD import is the best option.
How to convert a PDF to a DWG in AutoCAD
Another solution is to attach the PDF thru xref::
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Is your PDF a Scan? or is an image actually embedded in the PDF?
Converting to drawing objects really requires a vector based PDF to get something remotely usable, Any other flavor of PDF is probably best handled using the PDF as a background and drawing on top if it with lines, polylines, etc.
