- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Drawing from .dxf-import to QGIS is situated off the CRS
I created a drawing (extent of an area) in Autocad LT 2021 which I want to import to QGIS. In QGIS are the boundaries of a city which should be overlayed with my drawing. My drawing is already geopositioned in AutoCAD in the CRS ETRS89.UTM33. I have set everything in the right CRS but the drawing appears beyond the extent of the worldmap. I can't just not find the mistake. Can somebody tell me what went wrong? Deepmaterial
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi @azharali0917,
Welcome to the Autodesk Forums.
Need a few more details. Technically, AutoCAD LT can't Geo-Reference. How did you create your drawing? And in QGIS are you using a Shapefile?
Can you post your drawing and data for checking? (Zip everything together)
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I have a similar problem. Ive been sent an dwg file and I dont know if it has been set with a CRS or not. When I importet it into QGIS, I chose the project CRS in the import dialog. The layer ended up being somewhere else then intended. I tried to reproject the gpk I created from the dwg file again into the project CRS, but nothing happened. Im totally inexperienced with AutoCAD files. Can someone explain the issue?
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
@carla_brunowsky wrote:...I importet it into QGIS, I chose the project CRS in the import dialog...
QGIS support is elsewhere, start there
https://www.qgis.org/resources/support/commercial-support/
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Hi Carla,
Please attach your dwg, any other files, and a location where it's supposed to be.(Latitude, Longitude, or city) Best to zip everything together. Forum limit is 71MB.
Dave
Dave Stoll
Las Vegas, Nevada
