- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
David,
as shown on the first photo you uploaded, the page scale you have, is set to 1:1000 (which is 1mm = 1 unit).
The text you instered has an annotative slace of 1:1000. When you inserted the text object, did it take this scale automatically, or was it 1:1 and you changed that later, upon insert?
I believe it probably took the correct scale from the page set up, because on your drawing, if I add more text objects, they automatically take the 1:1000 scale.
On my drawings however, although my page set up is the same as yours (1:1000, 1mm=1unit), the text objects I insert they all take the scale of 1:1. I can change the scale of those objects manually afterwards, which is a little bit annoying, but I am wondering, how did you manage to make it work on your drawing?
