- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Problem with annotative text placed on paperspace when DWGUNITS = meters
Hi everyone.
I am having a problem with the size of annotative text objects which are inserted directly on the paperspace.
It seems that if you set the DWGUNITS variable to meters (option No 6), then any annotative text object that you place directly on the layout (paperspace) will not be displaced correctly..
Try a annotative text with let's say 5mm and see for yourself. Insert some text on the model space and then go to the layout and add some text there too.
One way I found to work around this it is to chage the page settings of the layout and define the scale equal to 1:0.001, instead of 1:1, but then the paper size instaed of being in milimeters, it is measured in meters, which is not ideal and may cause issues in some printers.
Another work around would be to have a seperate text style with the annotative option turned off. But I guess this solution becomes quite cumbersome because you will need to do that for every annotative object.
Is there any "proper" fix? I mean the whole purpose if annotative text is not having to maintain different text styles or to check the sizes of object when changing scales.
Thanks for your time.
Attached is the drawing, created with ACAD 2021
