- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
We have been having an issue with our Title Block block. It worked fine for years and now all of a sudden when we either use the Create PDF in the Acrobat tab or use Export in the Output tab our Title Block information isn't correct. Everything looks fine in the Paper Space as far as the text that's entered but when it gets converted we end up with extra fields in some of the information and now our Page numbers aren't changing, e.g. 1 of 4, 2 of 4, etc but we end up with all pages saying 1 of 4 and sometimes. If I open the pdf file and try to edit it there I end up with another problem. If I have, for example, a 4 page drawing and I change the last page to say 4 of 4 all of the sheets get changed to 4 of 4. I've edited the block in block editor to make sure the FIELDEVAL value is 31 and not 16. This worked for about 2 jobs and now it's back to doing the same annoying things. You can imagine this is #1, slow down our submittal process and #2 if we don't catch it it is embarrassing when your client catches it and rejects your submittals because they can't follow along on the sheet numbers. I've tried everything I can think of to fix this short of just creating a new title block our of frustration so if anybody can help I would be very grateful.
Thank you
¡Resuelto! Ir a solución.
