Kent1Cooper
en respuesta a: weekhong1212
@weekhong1212 wrote:
... when insert block file name uppercase to lowercase
Your image shows it not when Inserting it, but when Editing its Attribute.  Does it also appear that way in the INSERT dialog box?  And when you type this at the command line:
  (tblsearch "block" "test")
[replace test with the desired Block name], what is the case [or combination] of what it returns?
  ((0 . "BLOCK") (2 . "TEST") ....
And is it the same as the way it appears in the Insert or Attribute Editor dialog boxes?  And is it the same regardless of what case combination you type in?
Kent Cooper, AIA
