imadHabash
en respuesta a: Anonymous
>> When I type 'PO' and press enter, I can only select one point and then AutoCAD exits the command without any Esc
This is because it's designed to act like that .
>> when I select the Multiple Points in the expanded Draw panel, I can select as many points I want
This is also because it's designed to act like that . Here you select a different command than the first one .
>> Is there a system variable that causes this difference between PO and Multiple Points?
No .
Imad Habash
