jforde
446 Vistas, 1 Respuesta
Recommended USB Docking Station for DELL XPS 15 laptop
Hi - We are having using DELL DOCK D6000.       When Autocad 2022 is opened on either of the external monitors connected to the DELL Dock D6000 which uses a displaylink driver when moving the mouse over a drawing the cursor jumps all over the place.   In troubleshooting this issue I found that if Autocad 2022 is opened directly on the laptop screen then this problem does not happen but if opened or dragged to the external monitors the cursor jumping problem happens.
Can anyone recommend a external USB docking station that uses the laptop GPU and not displaylink driver.  Or jsut a docking station that does not have problems when using Autocad.
Thanks - Jerry
pendean
en respuesta a: jforde
Post a screenshot of your GRAPHICSCONFIG command pop-up please.
>>>... recommend a external USB docking station that uses the laptop GPU and not displaylink driver...<<<
Lots out there, sold by Dell and others you can find on Amazon, help yourself.
But... Have you reached out to Dell Tech Support yet? That should be your next step.
