06-28-2021
11:19 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-28-2021
11:19 AM
I imagine it would involve saving each Spline as a variable after it is drawn:
{whatever draws a Spline}
(setq spline1 (entlast))
{whatever draws the next Spline}
(setq spline2 (entlast))
Then you would have a distinct variable name for each Spline, which you could use in LOFT commands.
If you always need to Loft between adjacent Splines in the sequence of generating them, you could have one such variable:
(command "_.loft" ... use the spline1 variable and (entlast) ...)
and repeat.
Kent Cooper, AIA
