06-28-2021
05:03 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
06-28-2021
05:03 AM
I am trying to write a script which generates a set of spline curves in 3D space passing through a set of points. Once these splines are generated, I want to select two curves at a time and create a lofted surface between these two curves.
I can select these curves with the help of mouse. However, I want to automate the whole process and do it using scripts. Can anyone help me understand how to select a particular object in my autocad drawing simply through commands and without the use of mouse at all?
Thanks in advance!
¡Resuelto! Ir a solución.
