- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
moving a placed item to a dimension
I used to be able to do this, and I haven't used AC for a while and I cant remember how to do this, I want to copy and past a circle with an A in it that I have grouped and then use two dimensions to move it where its supposed to be.
can someone remind me how to do this
thanks in advance
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
For dimensions do you mean XY coordinates? If so the Command would be Move (basepoint) @4,5 or whatever coordinates you want. This only works if Dynamic input is off. There is a symbol to use with dynamic input on but I don't remember what it is. To turn it off type Dynmode on the command line and set it to 0. I hope this helps.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Thanks for the reply that not what I meant though.
I used to be able to edit this dimension and actually move the circle out to that dimension. let say I wanted this circle to be out 30 inches in stead of 27
