dm0144
1153 Vistas, 2 Respuestas
Print Offset in Layout space
Hello everyone
When ever I try to print directly from Autocad on custom paper size, the layout becomes offsetted from the paper, even though both are at the same coordinates (0.0) therefore, the print is slightly moved to one side.
To go around this issue, I use Window option to select the printing area instead of Layout in the Layout space.
Does anyone else encountered the same problem?
Any causes and fixes?
Regards
pendean
en respuesta a: dm0144
A screenshot of your PLOT command with the layout option ready to go would be better to post.
Do the same with your ABOUT command pop-up please.
travisgoffZ2B3C
I was experiencing the same issue. I looked for an answer here & elsewhere, looked at my plot settings, and was not able to come across what is very likely a simple solution.
So, my simple workaround (until I learn what is causing this) was to move my title block (& viewports, along with peripheral objects I keep in paper space) so that it appeared centered when plotting. I then made the same adjustment in my personal template.
I will move them back one day when I learn how to directly resolve the issue.
