pendean
en respuesta a: jsinobasN8VK5
>>>..."Bad definition of <Line Name> at line <number> of file <path of the file>"...<<<
That is a very specific error: I don't see that you did much to go to that line number or what you did to fix it, you seem to write about everything else. Do you just need to ensure those text styles are present in the DWG file? What else is on that line of code?
OR... share your ACAD.LIN file that is not working, let's see what you added and how it got added and if we can figure out what you forgot to do as a prerequisite to ensure your custom LIN definitions work well.
TIA
