jsinobasN8VK5
1409 Vistas, 16 Respuestas
Merge LIN files
Hello, I produce several LIN files that i want to combine into one single file.
the LIN files contains custom made lines that contains only a text between two continuous lines.
for example this "_X_" or this "-O-"
the problem that im facing is that when i tried to combine them all in one file by creating a LIN file and copy/paste the parameters into the new file i get the report of
"Bad definition of <Line Name> at line <number> of file <path of the file>"
the only detail about this lines is that they are linked to 2 different TextStyles.
None of them is using a shape. The folder that contains the file is already added to the support file search path as suggested here:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Bad-de...
can anyone help me? what im doing wrong? is there a command/routine to merge LIN files?
thanks in advance,
J.
