Kent1Cooper
en respuesta a: Anonymous
They're the insertion points of empty Attributes.  I find that GRIPBLOCK=1 turns on the grips in the other elements within the Block and turns off those Attribute grips, but you said you turned on grips within Blocks, which I would assume means you already have GRIPBLOCK set to 1.  I'm at an older version here, so it may work differently in newer versions, though Help for 2015/2016 doesn't describe that System Variable any differently, nor have any additional values available.  It doesn't say anything about the relationship of Attributes to GRIPBLOCK in Help for either my older version or newer ones.  I tried setting ATTMODE to 0 to make all Attributes invisible, but with GRIPBLOCK=0 their grips still show up when I pick the Block.  Hmmm....
Kent Cooper, AIA
