453 Vistas, 3 Respuestas
stuck display
Recently, my Office Computer keeps forgetting my screen arrangement.
Docked on the left, I usually have Sheet Set Manager, then, Layers, then Properties.
I've even this arrangement saved.
But now, there is the Sheet Set Manager properly docked,
but, the Layers is now a little rectangle that is unusable AND blocks the top of the display.
See where "61/128" is repeated.
The cursor cannot even move to the top of the display.
It has worked fine for months, but, now it is cursed.
I must have changed some setting.
Restoring the saved arrangement does not restore the display.
ANY IDEAS OUT THERE ???
pendean
en respuesta a: Anonymous
Ensure LOCKUI is turned off.
After you re-arrange your UI, manually save your workspace with WSSAVE command, and wait for any error messages. If none occur, go back to LOCKUI to turn in back on. Now WSSAVE again to your current workspace.
Repeat for all other workspaces or all other AutoCAD profile you run.
HTH
Thanks, that helped some. Setting LOCKUI to "0" brought back the Layer Properties Manager, but, I still need "Properties", where I change color, linetype, Dimension accuracy. Right now, the dimensions are set to 1/256, where I'd like it to be accurate to "1/8". If I click on the "Properties" button at the top of the screen, nothing happens. How do I get Properties docked?
en respuesta a: pendean
I restarted the computer, then AutoCAD and it was all fixed.
Thanks for your quick reply
