678 Vistas, 13 Respuestas
Deleting grip mass?
Hi all,
 Been using Autocad for awhile, and had run into this situation a few years ago, but now of course I don't remember the solution. Or more likely it has changed since I am not that  smart but was able to puzzle it out. I have inherited some block drawings that are not acting the way they are suppose? to. When the block is selected, grips show as expected on the entity, but a mass of them also show a few units away off to the side. Paper and model. No matter which grip is selected, it affects the block. I turned on grips within blocks because I am inserting these into cells of a table. And with this mass attched to the block it causes the block not to center as needed. The question is --- is there any way to remove them without exploding/ redoing the block. No setting or command that I have used so far has any affect on them.
Any help appriciated and thanks in advance!
