rkmcswain
en respuesta a: peterm
@peterm wrote:
I'm currently running AutoCAD 2022, but I need to repair it as there are some missing elements.
However when I go through "Add or remove programs" and select Modify for AutoCAD, it tells me that everything is up to date and doesn't give me the repair option.
A "Repair" is used to replace program files, like you might need if you run CCleaner or some other similar rogue app that damages files it shouldn't.
What are these "missing elements" you are referring to @peterm ?
