sameer.chavanQK8C8
1055 Vistas, 2 Respuestas
FBX file not import in Autocad 2018
I have created an FBX file from Navisworks simulatate 2022 and trying to import it in AutoCAD 2018. I have followed the AutoCAD 2018 Import method and it's worked also but at the end of the import in AutoCAD 2018, we can't find any object imported in the AutoCAD 2018.
Even, this same FBX file I have imported in the 3DS Max and exported as DWG & DFX to import into AutoCAD 2018 but the same result as above.
Please let me know how I can get the Navisworks model (NWD) inside the AutoCAD.
i tried but no objects in your fbx file try again to export?
https://knowledge.autodesk.com/support/navisworks-products/learn-explore/caas/CloudHelp/cloudhelp/20...
Thanks for notifying me. I will try to create a new FBX file and try to import it in AutoCAD 2018.
