nrz13
en respuesta a: nikm42Q9N
If you turn off Hardware Acceleration (enter GRAPHICSCONFIG at command line), does that speed things up?  If so, it could be related to your FirePro graphics drivers.  You might try to see if a newer driver version helps.
Are your Properties and Layer Properties Manager palettes closed?  Those can slow things down some.  Command line floating or docked?  I think docking it has helped some in the past.
Other than that, I'm out of ideas without knowing more specific details about your setup and how you've configured AutoCAD.  As has been suggested, a Screencast might help shine more light on the situation.
Work:  AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-8700K, 32GB RAM, Samsung 960 Pro SSD, AMD Radeon Pro WX 5100, 3 Dell Monitors (3840x2160)
Home: AutoCAD 2022.1.3, Windows 10 Pro v22H2 64-bit, Intel Core i7-11700, 64GB RAM, Samsung 980 Pro SSD, NVIDIA Quadro P2200, Dell Monitor (3840x2160)
