hencoop
en respuesta a: Anonymous
If you allow AutoCAD to assist you in typing the command (suggest the one you want) it will often give you what you don't want... unless you wait longer than the delay you have set.  Try either turning off suggestions or setting the delay to a longer time so it won't suggest something before you are done.
AutoCAD User since 1989. Civil Engineering Professional since 1983
Product Version: 13.6.1963.0 Civil 3D 2024.4.1 Update Built on: U.202.0.0 AutoCAD 2024.1.6
                        27.0.37.14 Autodesk AutoCAD Map 3D 2024.0.1
                        8.6.52.0 AutoCAD Architecture 2024
