- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
WHY ? and how can this be changed ? No, not interested in reformatting and changing the CO command to C - because that is the circle command 25 years ago and today
same for Mirror ??? MI always triggers Move ???
Many others ... SL goes to Stretch
ok when i type real slow it works ... but that is so sad
3D ... 2D slice command no longer works in certain instances ???
3D rotate along an axis ??? disappeared ?
Just venting because if you have a command and you had it for 30 years - keep it - so old guys like me can use it
I would suggest all cars for software developers should have the gas pedal and break pedal switched - just so you look like a complete idiot when you drive. (hey, in rush hour you use the break more often than the gas - that is why we switched it - Karl and Gottlieb or Henry in the US were fools to use the pedals the other way )
have a good day
¡Resuelto! Ir a solución.
