gabrielUMFVH
591 Vistas, 2 Respuestas
Pallet Icons Block Images to Small
Hi
(I'm using 2018 AutoCAD)
I have a Master Drawing I have all my blocks in, when I add them to a pallet (dreg and drop and design center) some appear very small. I work out that it was the width of the MTEXT in the blocks that appeared to be causing the issue, so I have redefined all the text width to a suitable value. but this didn't solve the issue (in the master drawing). I ran BLOCKICON and no luck.
But if I save the Master as MasterX  the images are perfect, but then if I save the MasterX as Master and create an new pallet, the images are small again. I even created a pallet in MasterX, all good and then changed the pallet mapping properties to the Master drawing and the images redefined themselves to be smaller.
So it looks like the images for the Master are Cached somewhere, how do I clear them or is there another solution I'm missing missing
