id_11
827 Vistas, 2 Respuestas
MLEADER Landing distance
If I have an MLEADER with a Landing distance = 0, I don't have the option to add another leader when you hover over the node point. See attached.
How can this be achieved?
Etiquetas (1)
Etiquetas (1)
vinodkl
en respuesta a: id_11
Hi @id_11
You can only add another leader using the grip when you have the landing distance set more than 0. BTW I find it easier to add leader by typing the command "MLE" and then select the multileader to add/remove leader rather than using the grip point :cara_guiñando_un_ojo: which works well in your case :cara_con_una_leve_sonrisa:
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
id_11
OK thank you for clarifying.
