en respuesta a: john.vellek
is there a solution to the question available in the meantime?
I have the same problem. We want to migrate connected .dwg files from Fileshare to Sharepoint Online. As the storage location (link) will be changed I assume that the links will not work after migration.
I am looking for a solution that the .dwg files will be connected after the storage location changed. As we have several thousands of drawing a manual solution is no option. We are looking for a solution that fix the issue azutomatically, for example by giving the old and the new path to the application and then it should replace the links in the connected drawings.
