eben0005
385 Vistas, 4 Respuestas
how to remove dulicate blocks
In Autocad 2022 as a student, I've created many versions of the blocks. Is there a function that can remove the unusable error stricken blocks permanently from the program so I only have the proper working ones show in the blocks tabs?
Etiquetas (1)
  • blocks
3wood
en respuesta a: eben0005
You can try command PURGE.
eben0005
en respuesta a: 3wood
thanks for getting back to me.
I've tried purge many times and does not remove these block from the library box.
3wood
You need ERASE them from the drawing first then PURGE.
pendean
library box?
