12-02-2015
05:42 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-02-2015
05:42 AM
Yep spotted the problem.
If you look at the properties of the text in the first tab you will see the text height is set at 2.5
If you also look at the text contents near the beginning it says "{\H0.8x" This is because the text size in the text has been manually set to 2 which is .8 of 2.5
Now since you are selecting all the text you are copying the .8 part which is why your text is pasting at 1.6
What you need to do is manually go into the text select it all and change the text height to 2.5. Then you can change the height back to 2 in properties.
Howard Walker
