Kent1Cooper
en respuesta a: devitg
@devitg wrote:
... I am attempting to connect two curves with two separate radii .... I am only given the radius and length of each curve. ...
[Where did that come from?  Did they also post on another Forum?]
If that's really the issue, you may be able to use >this<, which will let you draw an Arc knowing its radius and length.  If they're supposed to be tangent, I would suggest drawing a horizontal Line, then use ArcLength.lsp to draw one of the Arcs, and do the same again for the other.  That way you'll know each starts off tangent to the horizontal, and you can Move them together [and perhaps Rotate or Mirror one of them, depending on the relationship], and know they're tangent to each other.
Kent Cooper, AIA
