jocke.o92
en respuesta a: Patchy
I am can barely read code, I will start to learn soon but for now you could say I know nothing.
I just read the instructions in the code "Place a block object in the location of selected point objects".
Mby I am doing wrong or something. So I create som points in one layer, add one costum symbol to the drawing and center it over a point and make a block out if it name it exmple "1".
Now I run the command and it says "block name" where I put in 1, and then select objects, and after that nothing happens.
So hard for me to understand that Autocad doesn't have a simple creat own point style or something like that. Sounds like this expensive software would have something that made it easy to creat symbols to apply for a lot of objects :cara_asombrada:
