jtohill
en respuesta a: jtohill
If you are not using sheetset manager, then you can just modify the attributes to what you want it to say. If you are using sheetset manager then you would have to modify the sheet custom fields in sheetset manager. I use the manager to set the sheets up and it would bring this file you have from a template file with this in paperspace. Not sure how you are working with this file so will wait for the correct response.
