Karol_Piroska
607 Vistas, 3 Respuestas
blank mtext
has anyone had an issue with mtext going blank with just outlines of the text fields? I can still select it and it shows the value in the properties panel, but the text is not visible.
See attached isolated sample.
Etiquetas (1)
  • mtext
user181
en respuesta a: Karol_Piroska
Set QTEXTMODE to 0. You may need to do a regen after.
imadHabash
Click on below image to see how by QTEXTMODE (System Variable) = 0 and Regen command you can solve your issue .
Imad Habash
Karol_Piroska
@user181 @imadHabash thanks a lot guys!
