ODO18
663 Vistas, 7 Respuestas
Script to Place Point in Zoom Extents and Extract X,Y and/or Lat/Long
Trying to do some file data mining.  My idea is to extract into a txt file the dwg name and location along with the datum and x,y of a point and/or lat/long.  My script deletes and purges everything out of the dwg except our property line and then zooms to extent and then I execute the following point placement and data extraction.  I am trying to use the acconsolce for this so commands are limited that I can use.
I am stuck on finding a way to place point in middle of zoom extents and then getting the x,y of that point.  This is what I have for the calling of the data I need which includes file name, location, and file datum:
POINT ????
(setq ftkeepname (open "c:\\users\\xxx\\Documents\\Filename.txt" "w"))
(write-line (strcat (getvar "dwgprefix") (getvar "dwgname") (getvar "cgeocs") ftkeepname)
(close ftkeepname)
Any ideas?  Thank you
Etiquetas (1)
Etiquetas (2)
