- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
The data is there, its just a little messy and a long walk around to get there. Each text has an x, y and the polylines will have relatively close x , y. Dataextraction does not pull the polyline x , y so you would need somehting to pull this info for you. Something like ( http://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/data-extraction-from-polylines-and-ar... ) I would pull the verticies and lengths. You can match the lengths to the information in the data from dataextraction and you can get a fairly good approximation by matching the x , y of the Text and the Poly line verticies. You will have to do a lot of excel work to get this to work and you will undoubtably have to deal with problems with proximity of the text coordinates and the poly line coordinates so a QC would have to be run, but i think it might be doable. Given the scope of the task i would give it some thought.
CADnoob
