05-13-2021
08:26 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-13-2021
08:26 AM
Make the fill-in Hatch patterns again, but this time as Associative Hatches. That will tie them to their perimeter bounding objects, so when you edit the shape of those, the Hatches will adjust accordingly. You can just pick on a Hatch pattern and see its Area in the Properties palette.
But I confess I'm not quite sure what you mean by:
- Coherence between the two objects (keep the two lines creating the border as separate objects that are "tied together" such that moving one line moves the other)...
Is that about a double boundary between pool and deck [the image isn't quite clear about it], that should remain in two pieces paralleling each other? If so, that's a separate problem....
Kent Cooper, AIA
