- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
CTB problems
Hello Everyone!
So I just upgraded from CAD 2018 to CAD 2022, and for some reason when I import the CTB that I been using for quite some time now it doesn't overwrite the settings. When I plot, all my lines are super thick and is not reading the correct CTB line weights. I imported the CTB in the right location but for some reason is not detecting my settings, can someone please let me know what I'm doing wrong? I need to submit a set of plans tomorrow to the client and Im desperate.
Please see attached my screenshots how is currently plotting vs how it was a week ago before upgrading to 2022
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
I haven't used CTB files in decades, I prefer using lineweights, white screen background, and black/gray line colors when making 2d construction drawings. BUT...
Have you verified in "Plot options" in the plot dialog box, that "Plot object lineweights" is unchecked (desireable if you are using CTB files) and "Plot with plot styles" is checked?
crazy autocad witch since release 8
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
please see ctb from 2020. I dont have access to the old one 2018. I just had a saved PDF
Please see image 4. Lets take A-windows layer as an example. in my CAD is reading as 0.9mm and in my CTB is set at 0.1MM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
That might be your problem. If you are using CTB files, you should un-check "Plot object lineweights".
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Your CTB file sets yellow to .01", which is .25mm. But your layer properties sets that layer to .09mm. Since your CTB file is measuring in inches, try setting that yellow to 0.004" to match the .09mm setting in the layer properties.
Or... since you have lineweights set for those layers, don't use the CTB file, just use object lineweights and don't use plot styles.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
Our files and your CTB is not going to work.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
