- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
Problem with printing when save as .pdf
I have a problem in printing the .pdf files saved from AutoCad.
I have saved the pdf of multiple layouts (entered command "publish" and then plot the selected layout). I have printed that pdf binder from different printers, and the problem is line weight is different from different plotters, and with some printers, few lines are invisible.
Could anyone please help what is the reason behind that? I supposed that the PDF should be the same regardless which printer I am using.
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
- Denunciar
There are a lot of variables in that: color choices, print resolution, ink cartridge condition, etc. I would suggest choosing to print all black, and set the print resolution to 300dpi or lower, and see if that helps bring more consistency across printers. If that is not going to be a viable option, then check your lineweight and color settings in the dwg.
crazy autocad witch since release 8
