12-01-2015
12:04 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
12-01-2015
12:04 AM
the PDF does not hold any distances except the page size, so if you printed something with scale 1:50 to the PDF you need to scale back with factor 50 to get the geometry in the correct size.
If you don't have the scale within the PDF then you can use command _ALIGN to get the PDF-object scaled/rotated/aligned to an existing geometry. If you don't have a geomtry in the drawing then look for any object in the PDF which has a dimension (printed in the PDF), create a line in your AutoCAD with the distance of that dimension value and use then command _ALIGN and use this dimensioned object in the PDF as reference in the PDF and use your line to be aligned to.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Alfred NESWADBA
