Alfred.NESWADBA
en respuesta a: Anonymous
>> I use the font DIN Light
I don't have the font and I don't have the drawing, so it's guessing and questions:
How did you create that text? Copy & paste from another problem and this is now a OLE-object?
Is that a block, are that attributes or multi line attributes?
Are that single lines each with a TEXT or are they MTEXT-objects?
If MTEXT is the font assigned within the MTEXT or do you have defined a text-STYLE and used this without any internal style-overriding?
If it's well structured there should exist one or more styles using that font ... what happens if you change these styles to any other true-type font like "Arial"?
>> When I used Autocad 2015, I had no trouble at all. Now that I use 2016
Have you installed the latest service pack for 2016?
Is it the same workstation or is AutoCAD 2016 now running on another computer or a new operating system setup?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
