j.palmeL29YX
en respuesta a: kali.mailhot
@kali.mailhot wrote:
 Right now on certain files Autocad 2021 will freeze up and crash the computer.
What are certain files? Are they very big, do they include complex 3D-geometry, ... ? On which files does that happen and on which files not? Can you post such an example file here please and tell us which command is running while that happens? In some cases it can be that AutoCAD needs a lot of (or nearly all available) RAM. But then it (AutoCAD) should not freeze, it will "only" work very slowly.
is there a way to limit how much RAM Autocad 2021 uses?
I do not know any way to do this.
Jürgen Palme
