05-04-2021
06:12 AM
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
- Denunciar
05-04-2021
06:12 AM
1. What does that mean? We can't see what you are doing. Works fine here as always.
2. Did you move from LT by chance to full AutoCAD? LT's quick little handy command is not found there. Or did you forget to install a custom LISP or something else that you had in older versions? Or is PICKSTYLE not set correctly?
3. Watch the commandline to reactivate multiple option: or use COPYMODE command for change it. You do have that turned on and taller than a single line, yes? And you look over there often, right?
